2016 110 SE engines...
Old 03-09-2018, 06:19 PM
Badbagger's Avatar
Badbagger
Badbagger is offline
Default 2016 110 SE engines...
How reliable are the late model stock 110's ? Found a Road Glide with a stock 2016 SE 110 engine, it's only got 650 miles on it but my concern is down the road in 30K miles. Especially comparing those to the M8's.
Old 03-09-2018, 07:06 PM
J F GO's Avatar
J F GO
J F GO is offline
Received 3,346 Likes on 1,746 Posts
I'd say it will depend on how well you take care of it, how you ride it and how well you maintain it. I own a 07 CVO RK and most of the problems have been "me". If it's a good buy and you can afford it I say go for it. Good luck
Old 03-09-2018, 07:28 PM
bensonjv's Avatar
bensonjv
bensonjv is offline
Concur.
I have 15K on mine. I do regular recommended maintenance I do ride it like I own it. I don't baby it but I don't beat on it either. No issues. A little warmer than I like it in summer stop and go rush hour traffic but that's about it.
There were some teething problems in 110 TCs dating back to 2007 time frame but I would say most have been worked out. Even if not, you now have trends established so you know what to look for. You can also swap out parts you know have a likelihood of failing. For example, the 99c lifters are a common fail item reported here. Why wait until it blows up? Spend a couple bucks for SE lifters and adjustable push rods. An hour or so in the garage and you have the piece of mind that those are done. A lot of the pre-2007 crowd did preemptive maintenance like this; swapping spring loaded for hydraulic cam chain tensioners and swapping to the auto-adjust primary chain tensioner.
If you can find a good deal, absolutely go for it. Rumor is TC values are dipping faster than normal because of the new M8 release. That may translate to better pricing for you. Don't be too dissuaded from what you read in the forums. Its logical you are going to see more collections of people complaining about problems here. You don't get as many people praising the bikes or reporting no issues because they are out riding.
Old 03-09-2018, 08:21 PM
RedNose44's Avatar
RedNose44
RedNose44 is offline
Received 7,083 Likes on 2,600 Posts
Almost 20K on my 16 CVO SG with a stage 1. I don't baby it, and have had no issues. I am thinking about changing the lifters as a preventative measure.
secular (03-09-2018)
Old 03-10-2018, 12:01 AM
secular's Avatar
secular
secular is offline
At 15K on my 2015 FLHXSE. Same story here, Stage 1, she sees some spirited riding. I do give thought to swapping out the lifters before they start to get loud or just crater on me... I’d probably go with S&S.
Old 03-10-2018, 05:25 AM
kojak's Avatar
kojak
kojak is offline
Received 2,492 Likes on 1,243 Posts
Owned 2007 cvo road king 25 k miles, 2010 cvo street glide 15k miles, 2013 cvo road glide 30k miles with no major issues.
Old 03-10-2018, 08:26 AM
Serdvd6's Avatar
Serdvd6
Serdvd6 is offline
I have 21K on my 2016 FLHXSE, I also have stage 1, its going to go out of warranty this July, I will be installing S&S Premium Lifters and Rocker lockers, there has been quite a few 110 engines that have been taken out by a lifter on the CVO forum, but who knows how many engines are untouched?
I'm not taking chances as I don't have a ESP, but for a few dollars and a couple hours of work I should be ok.
Old 03-10-2018, 11:02 AM
miles miles miles's Avatar
miles miles miles
miles miles miles is offline
I have 29k on my 2016 and rode it from day one the same as I ride all my bikes..Hard! I go through tires a bit quicker sometimes but no issues at all. This is the first that I will keep past my usual 2 years since thats only in a few weeks.
Old 03-10-2018, 09:25 PM
nytryder's Avatar
nytryder
nytryder is offline
I'm changing out my lifters when 15000 miles roll around. S&S lifters will replace the stockers. I'd wrather spend a few bucks for insurance and peace of mind. The 110" engines can easily be upgraded to a 117" if the mood should strike. TheM-8s are very restrictive on many popular common upgrades at risk of loosing drive train warrantys. Hope this helps.
Old 03-12-2018, 04:37 AM
Mofo67's Avatar
Mofo67
Mofo67 is online now
Is the motor a factory 110 or a 103 that was built up to a 110? Harley makes a 110 kit with CVO heads but it runs lower compression than the stage 4 tire shredder and performance was also much lower. Also no throttle body upgrade with this kit. We have a local dealer that does a few custom bikes every year and they use a HD paint set and motor upgrade. These turn out to be high dollar mods, normally selling for $50k+.
Quick Reply: 2016 110 SE engines...
