Code b2116 and code b1213
Old Aug 15, 2022 | 03:57 PM
Hogs4fun's Avatar
Hogs4fun
1st Gear
Default Code b2116 and code b1213
Hello all,
Got a 2015 Street Glide CVO, after doing some work on it such as tour pack install and front speaker change, I tried starting the bike and notice the battery being weak.
I figured it was normal since I had the bike ignition on and off several times checking all the lights. So I changed the battery just enough to get it started when all the sudden the engine stopped running saying low range fuel and I got the codes b2116 and b1213. I did have the tank off and I remember getting the fuel low range then when the fuel line was disconnected. However when I put everything back together everything worked fine other than the battery being weak.
I tried finding things on google but no luck. I find all about code clearing but that didn't fix it . Fuel gauge shows 0 and low range is on.
Anybody knows what to do with that? Any help much appreciated.
Old Aug 15, 2022 | 08:37 PM
Hogs4fun's Avatar
Hogs4fun
1st Gear
I guess I figured it out. Left of the battery is a connector in the middle of the dept of the battery which has a 10 amp fuse.
I disconnected it and reconnected it and the low range went away. Go figure all about computers these days.
Just in case somebody else has the same problem.
Mac24
Jul 26, 2021 03:44 PM
Barty
May 15, 2018 09:18 PM
CVORoadKing2013
Aug 7, 2012 08:10 PM
Redmondp
Mar 28, 2011 12:56 PM
gremlin1325
Apr 30, 2010 08:25 PM
