Shovel build from a pan
Had my pan for a while and wanted to get rid of the pan so I totally stripped it down to nothing and knocked all the bondo off... Looks pretty ugly so gonna have it sand blasted......
After sand blast I'm going to cut the neck but I just want to rake it with no stretch, what is the maximum rake would I be able to run and how many " over would it get me? Just need some Ideas
Received 3,220 Likes
Attachment 409769
Attachment 409769
Attachment 409769
Attachment 409769
http://207.57.8.251/tools/rake_trail.html
Ultimately you want to keep your trail between about 4" to 6" for a chopper and this calculator will help you in deciding what needs to be done. For example on a Street 750 rigid chopper build I'm doing I'm going with a 12" extended girder fork (42" overall), a 36 degree rake, and a 25" dia tire (19" rim). To do this I need to have a 3.25" triple-tree offset to achieve a trail of roughly 5".
In the old days we had to either trig out all of this crap or just guess at it and today's online calculator makes it very easy.
Of note I'd highly recommend that you have a certified TIG welder do the re-welding of the fork head and have the weld x-ray inspected for any defects. Weld failures resulted in many deaths in the 1970's because if the head weld breaks it launchers the rider head-first into the pavement. The costs are insignificant because your life is literally dependent upon this critical weld.
Rigid frames are about $1,000 and swing-arms for about $2,000. Save the original frame because it cannot be replaced. Someone will want it and might pay you as much for it as it will cost for the Paughco frame. If you want to change the rake then do it on a Paughco frame.
http://www.paughco.com/2008-catalog/...20Paughco.html
Bear in mind that the handling characteristics will be much different and at low speed suck on a raked and stretched bike. They may look cool but that's about the only thing they have going for them as far as I'm concerned.
JMHO
LiiT
