Shovelhead issues
So, the bike I bought doesn't want to start. It's been sitting for quite a few years now, but is still in decent visual shape.
When I go to start it, seems like the fuel filter isn't filling up with fuel, and is also leaking a little bit from the brand new petcock I've installed. Seems like no matter what position I put the petcock in and tighten it, it still wants to leak. Also, it's "puking" oil from the crankcase hose. Now, I've read the reason as to why this happens, I just want to know how much should be coming out? I'm in no rush to fix that end of the things as I just need the bike running for a friends wedding, to take pictures with. I've already changed the oil, plugs, sealed the tank with the POR-15 kit, and put a new battery in it. Any suggestions would be greatly appreciated. |
Sitting for quite a few years...
Have you taken the carb off and given it a good cleaning, made sure the jets are not plugged with dead old gummy gas? Try some plumbers teflon tape around the threads of the petcock. Should do the trick. Puckin oil is common for a bike that has been sitting. Just pressure build up and will ususally quit once the motor runs and oil get circulating through the system. But since it hasn't run in a bit I would pull the cap and inspect the check ball to make sure it is not stuck from sitting. Also pull the plug on the tappet screen and make sure it is clean. The external fuel filter is redundant and not needed if you have the filter in the tank. And check to see that the external filter is mounted properly. There is usually an arrow which shows which way it goes. The filter has a paper element that should probably be replaced as well if you intend to use it |
(Post 14013109)
Have you taken the carb off and given it a good cleaning, made sure the jets are not plugged with dead old gummy gas? Try some plumbers teflon tape around the threads of the petcock. Should do the trick. Puckin oil is common for a bike that has been sitting. Just pressure build up and will ususally quit once the motor runs and oil get circulating through the system. But since it hasn't run in a bit I would pull the cap and inspect the check ball to make sure it is not stuck from sitting. Also pull the plug on the tappet screen and make sure it is clean. The external fuel filter is redundant and not needed if you have the filter in the tank. And check to see that the external filter is mounted properly. There is usually an arrow which shows which way it goes. The filter has a paper element that should probably be replaced as well if you intend to use it Plumbers teflon tape, will give that a shot. The bike does not have an in tank filter, and the filter is new. But I will check to see if I put it in the right way. In regards to the check ball, if it's stuck how should I go about freeing it? Thank you |
If it puking oil the ball is probably not stuck since it is leaking past it. To remove the ball put a magnet on the side of a steel rod. That should should magnetize the rod enough to lift the ball out.
Crack the gas caps open and see if you get fuel, had a few with plugged vent ports that causes the tanks to vacuum lock on you. Far as the puking out the vent hose that isn't uncommon for ones that have been sitting, cases can hold 1-1/2 qts if it bleeds down that far. Put a pan under the bike when you try to start it and after she's running the first fews times you let it sit overnight they usually settle down after you run them while, it doesn't post back I'll link you to a repair post with pictures for reseating the check ball properly.
How does one go about emptying all the oil from that portion of the system? Seems like it smells a little gassy.
(Post 14014681)
It just sounds like you really need to sit down with the bike and do a good cleaning from top to bottom. |
Originally Posted by AlCherry
(Post 14021846)
What he says. If you are smelling gas in your oil, it has leaked down thru your carb, by the rings and into the crankcase; Change the oil immediately. Gas doesn't make a good lubricant. You'll need to change it again once you get it started and warmed up. It all goes back to your carb. Possibly the float is stuck open. By the way, what kind of carb are you using?
It just sounds like you really need to sit down with the bike and do a good cleaning from top to bottom. Although this looks like really really bad news. https://cimg0.ibsrv.net/gimg/www.hdf...873ef90e40.jpg That's not even a 1/10th of what I dug out of the primary. Colour me worried. :icon_violin: |
Somethings rubbing somewhere , was the primary chain loose ?
the chain or belt with an idler was adjusted on the tight spot not the loose spot
© 2024 MH Sub I, LLC dba Internet Brands
