Got me a shovel
Cool bike! I find the printed HD service manuals better for the bench... I read the PDF when needed, but having the paper manual on the bench in the shop is valuable in so many ways. I write notes in them, get grease on them (oops), etc. Also a handy place to keep my beer, so I don't need a coaster in my shop.
Enjoy the bike and I agree with others - keep us posted with news of your efforts!
And yes - UK as in across the pond. Where nice shovels are pretty rare. So I am pleased to have found this one....
Sadly, the weather is lousy in Europe right now, so I don't foresee much riding time. I really don't want this one to get caked in salt and road grime right now....
Well, I guess I may as well use this thread to document the journey with this bike....
Not much done today - it's way too cold to be in the garage. But I did do a compression test and got the following results:
Front 130 psi
Rear 126 psi
The spec in the manual says compression should be over 100 psi and a variance of less than 10 psi between the cylinders - so all seems good there.
Also went and got a new oil filter and four quarts of Spectro 20W50 oil. Should have picked up some tranny fluid at the same time, but I can do that tomorrow.
I noticed there is some mild leakage that looks like it might come from the transmission main shaft seal. This seems extremely common on these bikes, so I did a bit of searching on how to fix and ended up ordering a replacement spacer with built in o-ring from "saddlebagrail". When that arrives, we'll see if it fixes the leak. There were some very good reviews on this approach though.
I did have a "doh" moment earlier though. I took the seat off and thought I would gently take the oil filter cover off while the bike was running just to check oil was coming back into the tank via the return lines. I won't do that again as I ended up with about half a pint of oil on the garage floor in a split second. So I guess the oil flow is good at least....
TSheff asked me to post a pic of the original seat - but on closer inspection, it doesn't appear to be original after all - I can't find any part number on it, but on the underneath it does say "SEP 92 937" - which I'm guessing is a date code and serial number. Pic below in any case....
Front 130 psi
Rear 126 psi
