Lifters and push-rods - I need advice.
Here's what I took out:
After watching a few vids on assembling shovels, I came to the realization that something is different in the pushrod department.
I wasn't the owner of this bike until it had sat in a garage, disassembled, for about 20 years. The previous owner didn't keep notes.
Are these solid lifters? Can they be identified?
How would I go about installing and adjusting?
Would I be better off getting new lifters and rods?
jon loder (03-30-2017)
setup to adjust is the same for both. with the solids tighten them till you just start to feel friction while twisting the push rods with your fingers. Take your time and try it a couple times before you decide to go to the next one. you DO NOT want them to tight. A little loose makes noise, to tight causes damage. Solids are NOT quiet they will make a little slight tick. I run solids and i like them. If who had the bike before you and did solids right he blocked off the oil port feeding them so if you decide to go back to hydraulics make sure to remove the plug.
