an emotional restoration
Received 3,212 Likes
Not your standard FLH. Quick giveaways are the 5-speed transmission, outer primary and the location of the oil filler
I had a peanut tank off of a '72 that was rustier than the titanic. I dumped an old coffee can full of random nuts,bolts, and screws in to the tank with just soapy water. Shook the hell out of it throughout the period of a few days periodically rinsing it out and adding new water and soap. It was unbelievable how well it worked. After that I experimented with the A and B prep agents from a Kreem kit that I had already and followed the directions provided. The tank was like brand new. I did not use the sealer. I just filled the tank with gas and it was good to go.
Thanks for the input everyone. I did the first step of the POR-15 which is just a degreaser and the tank is like night and day difference. It seems like what I was looking at what just the old sludge the hung around after I drained it. I can see very little surface rust in some spots though. Should I try the nut/bolt method to try and knock that stuff loose instead of continuing on with the complete re seal?
anubisss
12-24-2007 09:30 PM
