starter stays engaged
You should replace the spring! It's weakened if you need to stretch it for it to do it's job - it will fail again.
I opened it up, saw that the switch is sealed.
Put everything together again, tightened it up and made sure all the screws were tight. Turned the ignition switch to on, then hit the button and started the engine. No problems, after I made sure it all was tight! Motor ran good, starter did not stay on even after letting go of the button!
wrinspect21
04-04-2020 06:04 AM
goliath1
12-20-2012 05:09 PM
