starter stays engaged
No matter if the engine in the bike is an Evo...
You will get more knowledge on that starter configuration right here in the Shovelhead section...
The starter drive gear (bendix) is not the cause of this problem.
The problem is that the drive gear is not being retracted from the starter ring gear.
As V twins said, the problem can be caused by a weak battery, or bad electrical connections.
The first thing to do is remove the battery, charge it fully and then have it load tested.
While battery is out, clean all battery, starter solenoid and starter motor cable connections.
Here`s a safety note for anyone not familiar with this starter configuration:
Do not pull on the starter drive gear when battery is connected, doing so will energize the starter motor. It does not matter whether the ignition switch is on or not.
Has the battery been load tested?
Have you disconnected and cleaned all the connections, including the ground wire, battery to starter bolt?
[/QUOTE]
[/QUOTE]
