gasket sealer
04-08-2017, 11:13 AM
gasket sealer
Hi what kind of gasket glue should I use for inner outer primary?
04-08-2017, 06:09 PM
You can put it on dry. If you need just a lil' to hold it in place to start the outer primary bolts, black gasket maker smeared real thin in small areas works well.
04-08-2017, 07:01 PM
I use a little grease to hold the O ring to the motor, for the outer I use James gasket with that orange crap on it, if it leaks then I pull it off and spear a little RTV made for gear oil, Permatex #81182
04-08-2017, 09:56 PM
Shovel primaries I use Permatex Ultra Gray on the o-ring sealing surface and on the gasket it it's the cheap plain paper ones, better quality gaskets with the silicone bead install dry.
Loanshark
28
12-01-2019 06:09 PM
Jeff Dodson
General Topics/Tech Tips
04-23-2018 06:28 PM
LQQK_OUT
EVO
22
07-10-2016 11:25 AM
JustDave71
04-04-2010 01:00 PM
Bulldog21
08-21-2008 10:15 PM
