Smaller tank on a big twin shovel frame ideas
I love the design and look of the shovelhead engine. I currently have the fat bob set on my 84 FXSB and hate how it covers the top of the rocker boxes up. I am looking for ideas for how to mount a sportster style tank. I don't really want to cut the factory tank brackets off of the top of the fame in case I want to put the larger tanks back on. Has anyone figured out a way to mount some of the aftermarket "king" size sportster style tanks to a big twin frame?
Thanks!
Thanks!
No. no and hell no, you do not go cutting up intact shovelhead frames, save that **** for the sportster bobbing boy's.
OP you find a tank you want and get busy modifying that to fit not the other way around.
Hahaha just grind off the fatbob mounts, leave the frame intact....
On a side note there is nothing better than cutting up parts that other people find valuable. And making something cool out of it. Twisted, I know with all the bike stuff you know about old bikes(and that killer shovel), cut up a frame or two when you were a kid?
Besides any peanut tank will need tabs mods or additions and the stock frame tabs make good mounting points already.
Yamaharley (04-21-2017)
Thanks for the quick input. The original parts of my bike are all in great shape so I do t want to cut them up. I may want to go back to stock at some point, who knows.
Thanks for the link too. I'm not sure how I missed it because I check the forum pretty regular. My motor is a thing of beauty... I want to show it off proper.
I bought a new shovel back in 1974, when H-D made around 25k bikes a year. They make at least ten times that many bikes nowadays. So it is not the case that shovels were ever plentiful - they were always rare and still are! So I agree, leave the frame as is and buy a modern pattern tank to cut about and make fit. That should offend nobody!
MAN ---- try to find a 3.8 gal tank from a Super Glide from the late '70's it is great and still with some gal space , I found one on Ebay for $100 it will cover up the tube and be narrow enough , it was also used on the early '80's Sportster Roadster . You are right there at the frame change '84 new or old frame ??? that tank just might bolt right up , it is held on by 1 bolt in front and a spring in the back -- simple
