Inner Primary Off-what seals should I replace?
I needed to replace trans seals, so I figured I'd install a 32-amp alternator as well. So as long as it's all apart what seals do I want to replace?
Someone said to replace the motor seal. I think they mean the Sprocket Shaft Seal and Snap Ring. Will I have access to the Left Side Engine Case Seal?
The service manual shows a sprocket shaft seal, I think it's commonly called a motor seal. That's the only seal on the left side of the motor case.
If I took a front end apart, I'd change seals and bushings. If I have access to seals, I generally change them, unless it's been a ridiculously short time since i last changed them.
Hope you replaced the trans shaft sprocket spacer w/one w/o-ring. https://www.youtube.com/watch?v=Xsp238XVLgM Works great - not a bit of leakage. Mine came from SaddleBagRails:
The guy sells them on ebay too... or alt least used to...
Bill wallace (05-30-2017)
