rocker box oil lines leaky
I've replaced all the seals at all connections. I've cleaned the threads on the brass fittings and re-seated them a few times. However once the bike gets up to temp and has been running for a bit I get oil seepage from the fittings on the heads. Is there an alternative set up to run that has more reliable connections?
I'll keep that in mind.
I bought a set of these for the $16
http://www.ebay.com/itm/Rocker-Box-O...pYp2x4&vxp=mtr
Just gonna run the top one as that's where my problem is. See if it works or not. Could be garbage.
JohnJZ or other people here would know better, just don't install them until you hear a second opinion
OP You need to a decent thread sealant on clean non oily threads and not thread tape. Also I cut my own doughnuts out vacuum tubing, make them a hair fatter and leaks be gone.
V_twins (05-30-2017)
Doesn't matter which way they go as long as one side is the restricted port.
edit: just saw the link. Thanks.
Thanks for the input. Much appreciated.
Every set of those I have ever seen seep oil eventually around the crimps, good luck.
https://www.amazon.com/Permatex-5921...thread+sealant
Anyway... I replace the grommets of the OEM lines every year pretty much... good call on the vacuum tubing, will try that.
what size?
Also, I always used thread tape for oil/gas, but one leak is always there!!! Will try that sealant!
