ShovelHead help please...
This place is great, I hope to spend allot more time here.
Here’s the problem.
85’ FXSB 1340 shovelhead. Other specs below…
Recently this bike, I’ve only owned it 1 year, has developed an intermittent stumble under acceleration. Sometimes so badly that it felt as if it was going to stall but usually just a stumble. It comes and goes. Some rides it’s great some not.
The rear pipe started to blue really badly and now also the front pipe. It has been very hard to start when hot. Endless cranking with occasional backfires from pipes and occasional pipe fire. Initially thought the bluing pipes indicated lean, but the plugs have been black all along.
Here’s what I’ve done.
Checked out the ignition system per manual. Seems fine.
Replaced coil just for kicks.
I checked and adjust the float height to 3/16 below bowl gasket surface (it was too high) . I thought that the stumble might be bowl overflow when under G’s, Thought bluing, black smoke and fire could be un-burnt fuel in the exhaust. Am I off the mark here?
I would consider a jetting procedure next but jetting doesn't just stop working. Also, I haven't seen any consistency in the weather condidtions under which it stumbles. Should I do it anyway, and if so could you recommend a procedure that would get me in the ball park. I can jet 2 stokes all day, but I'm new to the Harley thing.
Here’s the bike
85 FXSB Shovel 1340
Never torn into, medium miles
Compression dry 140 front, 130 rear
S&S Super E carb, 072 main, 295 pilot, Idle circuit ¾ out, accelerator pump set at ¾ travel,
Stock ignition, aftermarket coil, aftermarket wires (not sure if solid core or not)
Straight pipes
Autolite 4265 plugs
Aftermarket ignition switch, a little touchy, have to have in just the right spot, but once you put some current though it trying to start it the switch works fine.
Please chime in if you can help. Don’t know what to look at next.
Thanks
Ian
First thing I'd do is replace that faulty ignition switch. If it's that finicky, it's going to leave you stranded somewhere.
HwyAP...
Out the carb lean or intake leak.
