Fuel Line Routing
Running between the jugs is a non issue and like FL54 says doing a wear sleeve of some kind isn't a bad idea, I've used everything from an extra layer of shrink tubing to a chunk of plastic split sleeve like on wiring looms.
Oh one more thing the ever popular little glass gas filter everybody uses ? Only thing they are good for is seeing the gas flow you already have a filter in the tank.
