'79 FLH-80 Keeps Eating Ignition Coils
I have gone through 3 ignition coils this year. I am using a compu-fire dual fire dual plug ignition. I am lost on what is knocking these coils out. I have verified that the wires and ground are good, the plugs and plug wires are good. Will a bad VOES or ignition timing being off effect the coils? Thanks for any help.
I run a pair of Dynatek 3 ohm on mine with a Dyna S ignition. Timing won't hurt coils, but current will. The only time I have lost coils was from leaving the ignition switch on accidentally for a week or so. Did this two different times over the years and killed coils both times. Now I take the key out of the ignition switch so I know it's off :-) Might want to be sure you don't have voltage going to the coils when it shouldn't be.
gcwil57 (07-29-2017)
