help with rear dual piston caliper 81 FLH
Having a bad time with my dual caliper stock setup - drags after a few applications of the pedal - seems to keep getting air in the caliper - dont have experience with this setup but Donnys book states this setup is the ******* of shovel rear brakes - pistons are not stuck - I have bled and bled and bled and have actually bled by compressing the pistons - they move smooth - has PM M/C with high end PM controls - no leaks anywhere - any comments appreciated
Received 3,220 Likes
Calipers and brake lines look stock but the rotor definitely is not. I would pull the rear tire, take the rotor off and see if it is warped. And if that is the stock brake caliper there will be a date code stamped on the caliper. The caliper is a two-piece unit. It will be stamped on the outside piece.
If your brakes system is to that stage of deterioration, I would fit a rebuild kit to caliper and MC and give the brake hose a good check over too. The hoses swell up after 20 years or so and the hole in the middle becomes restricted. Sometimes they will let fluid pass in one direction but not back in the other.
That caliper used a much thicker than usual rotor...like over a 1/4 inch......which that rotor is not...your pistons may be coming out further than they were designed to.
http://www.ebay.com/itm/NOS-Harley-D...RZIZmp&vxp=mtr
Yes - that makes sense - I noticed the pistons were out pretty far and I was thinkin' - wtf was Harley thinking with this setup - but then again - many things on HD bikes are like - wtf? so what are my options? I tried removing the rotor and the dang flat socket head screws are totally frozen - an impact driver just bent the snap-on bit - maybe machine up shims? or buy a set of pads and grind off the pad material to make a shim?
jbgoodner2
07-14-2013 12:47 PM
