exhaust leak
exhaust leak
on my new 79 flh I have a pretty bad exhaust leak on the rear cylinder, the pipe is a cyle shack 2-1
i replaced the gasket with these http://www.jpcycles.com/product/693-...SABEgLbSfD_BwE
and it still leaks the same. The pipe doesnt really seem to fit that great, it seems to be in a little bit of a bind. It sucks up tight at the bolt and has a small gap maybe you could fit a business card in opposite of the bolt.
this is the pipe i have for now. Are there better gaskets that may help me here or what do yall suggest. Also, Is it suppose to be bolts of is it suposse to be studs. Mine has bolts and one is noticably longer than the other. The long bolt will not thread all the way into the the other one. It bottoms outs.
Received 47,790 Likes
what do yall think of adding these wire mesh gaskets over the top of the ones I have
and it I do should I just use it on the rear cylinder or both
http://www.jamesgaskets.com/product/jgi-65834-98-x2/
AJSHOVEL (08-04-2017)
2003flhtci
Exhaust System Topics
03-28-2009 08:38 PM
