Rebuild on my shovel
I have to pull the motor and split the cases to find and fix an oil leak. I just went through the transmission. Any tips? They say Shovel heads are known for leaking. Yeas ago I had a 75 and a 78 and neither dripped one single drop of oil.
I don't want to have to do this again. That is why I am asking for experienced
shovelhead lovers. I have not been on a shovel from nearly 40 years.
Use Cometic gaskets, the metal/ silicon wafer ones particularly on the rocker boxes, James stuff isn't what used to be.
I use a bit of lapping compound on the case halves to get a good matched surface (be sure to clean very well when done) and Yamabond sealer on the crankcase seam, seals very nicely.
On my shovelhead the leaks at the case was the 2 bottom bolts I removed them 1 at a time ( had to raise engine 1/4 inch ) and put in copper washers on both ends
And another trans leak -- H-D left out a vent for the trans DUHHH a leak 1st year for the 5 speed, I cut 1/4 inch out of a fiber washer for under the dipstick , no more leak
If the crank does get pulled, balancing that assembly, makes a LARGE difference.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
