cylinder and spark plug foul out with black dry soot on rear cylinder only on a 1965 harley davidson servi-car 45 engine whats the problemm
1965 harley davidson servi-car rear cylinder spark plug is fouling out with black dry soot front spark plug is fine what can be causing this problem and how can i correct it i have tried to adjust the carburetor so its not running rich but still have the problem any help would be appreciated.
I would start by checking the manifold seals (the front one in particular) If the front plug looks good and the rear looks sooty it could be you over compensated the idle mixture screw to satisfy the front cylinder because of a leak and the rear is fine making it run rich on the rear cylinder......
Is the compression the same in both cylinders? Very well could just the hotter back cylinder just has cooked the intake valve seal and a little oil is running into the cylinder. My guess if it's fouling the plug and making it misfire, then it's probably not that rich with fuel because if it was, it would run like crap.
Oil does not burn, it's just cooked from engine heat. The term, pumping oil is really more appropriate then burning oil. Not sure when the engine was rebuilt but it can actually have close compression and the oil control ring in the back is stuck and complicated by a leaking valve seal.
I actually have a 1940-1958 Service manual on that antique.
police depts. and hardware stores were still buying 45 inch flathead trikes until 1973 from Harley New and they became electric start before the big twin in 1964
