Shovel head normal noises?
Old 09-06-2017, 05:28 PM
hellonewman's Avatar
hellonewman
hellonewman is offline
Received 5,720 Likes on 2,467 Posts
Default Shovel head normal noises?
Ive noticed aside from the lovely idle sound theres a random mechanical noise. Not a bearing but a sound from the transmission like gear rollover noise or a random mechanical knock. I isolated it to the rear part of the primary or transmission, its not the engine.
I ordered the factory shop manual, parts book and owners manual and I can do the work myself but Im still waiting for them to arrive. Im just wondering if these bikes normally make sounds like this or I have some work to do?
Old 09-06-2017, 05:30 PM
IronAss's Avatar
IronAss
IronAss is offline
Received 12,220 Likes on 4,770 Posts
Is it a dry or wet clutch. A dry clutch can sound like a coffee can with a bunch of change in it rolling down a concrete driveway.
Old 09-06-2017, 05:59 PM
hellonewman
Dry, has all the oil lines still in tact. Nice description btw.
Old 09-06-2017, 06:02 PM
81rat's Avatar
81rat
81rat is offline
To really isolate a noise try
Put a piece of pipe appox 1" x 2' of more put 1 end close to where you think the noise is coming from and other end at your ear , move pipe around to loudest point
Old 09-06-2017, 06:03 PM
IronAss's Avatar
IronAss
IronAss is offline
They will normally "chatter" whenever you disengage (pull the lever in) the clutch.
Old 09-06-2017, 06:08 PM
hellonewman
I did with a long screwdriver, Ive been a licensed car mechanic since 1986 and run my own shop. Just not familiar with what is normal on an old shovel head is all.
Noise doesn't change with clutch position, tried that earlier.
Old 09-06-2017, 06:46 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,519 Likes on 2,862 Posts
as lower unit sound travels some even to the handlebars,
locating a noise in a shovel --- well its the real reason drag pipes were invented
having said that the list of possible places is mind boggling
being it has you looking at the rear of the primary my guess you have bolts loose, between the motors 4 bottom three top trans 5 and the trans plate has 4 - the primary has 8 plus the starter housing and related parts
brake out the wrenches and confirm
Old 09-06-2017, 06:51 PM
hellonewman
Thank you. I need to fix an oil leak on that side anyway so Ill yank the inner case and everything in front of it.
Old 09-06-2017, 07:48 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
if the oil - its wet on the drive sprocket then its the hi gear bushing, the inside small seal is very small its only going to hold back Some wet ness not a flow from worn parts
also look at the counter shaft just in front of the sprocket 1 inch in diameter if the pocket is wet its the O ring seal - trans apart for both of those leaks
the primary its self has fittings and hoses don't wipe anything till you determine wetness and looseness in anything that might be the cause
hellonewman (09-08-2017)
Old 09-06-2017, 11:54 PM
Hurricane 68's Avatar
Hurricane 68
Hurricane 68 is offline
Default Only worry on mine
On mine it's a 75 shovel solid roller high compression kicker I only worry when it gets quite. So used to the noise makes it right. Bikes at 15 years riding speedo stopped at 12,000 when changed tranny to 5 spd that was five years or so ago Ride Safe. Wild Bill
Quick Reply: Shovel head normal noises?
