Charging issue? Hot battery
Old 09-09-2017, 08:59 AM
06Roadie's Avatar
06Roadie
06Roadie is offline
Default Charging issue? Hot battery
Having a battery issue. Bike is a 79 FXE converted to FLH. Only had the bike 2 months, working through some issues. Noticed she doesn't hold a charge. Week or so maybe. Anyhow, pulled the battery and the parts store tested it says it's good and it looks new. Went to turn her over yesterday and battery was weak and wouldn't turn over. Battery was pretty warm to the touch. Trickle charged in about 2 hours to full again. I assume something is drawing power when sitting maybe?? Or is the stator shot? Or a smoked battery?? Any ideas guys? Thanks
Old 09-09-2017, 09:07 AM
d_slat's Avatar
d_slat
d_slat is offline
Only you can answer your question here. Disconnect the battery leads when it sits and see if the battery goes dead then. If it does, put a new battery in. If not, you need to figure out what is draining it...
Old 09-09-2017, 04:04 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
the voltage regulator has a diode in it that is supposed to stop a back drain, like a trunk light on in a car, and we see they leak voltage causing the battery to be dead after a few days
Old 09-09-2017, 04:14 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,273 Likes on 11,143 Posts
Diagnose your electrical system per the stickies in the ekectrical system.
BTW...a trickle charger shouldn't have the ability to fully charge a battery in 2 hours. Maybe your battery is really taken no a full charge.
Old 09-11-2017, 11:40 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,916 Likes on 17,473 Posts
Battery got any water in it ? or you have the AGM type ?
Road Gliderman
Electrical/Lighting/Alarm
17
02-24-2019 12:34 AM
lol_paul_ledoux
04-06-2017 09:02 AM
Redd-Rider
01-28-2017 11:49 AM
matte
06-09-2013 12:53 PM
I8SMK4U
05-11-2009 04:18 PM
Quick Reply: Charging issue? Hot battery
