wide rear tire with a chain
My current rear says 5.10-16
Wide Tire
I picked up this 83 FLHS about a year ago and the PO or Builder installed wider wheels and tires. The wheels are the AKRONT 4.25 X 18 40 spokes with Avon 130/80 18's. That is absolutely the widest you can go on this bike with no offsetting. This bike also has the final belt drive as opposed to a final chain drive. Space between tire side of the fender is so limited, no fingers can get in between which means no room for any kind of protruding hardware unless you want those tires cut. Looks cool as hell but turning / leaning the bike is a bit of work and definitely a learning curve. Front end definitely feels heavy and maybe a bit more stiff? This is compared to the 78 FLH I have but again, the 78 has had a sidecar attached to it for the past 11 years so this is going to be different anyway. Also compared to my Roadking is night and day. The closest I could come to comparing it to would be the 78 if I were to pull the sidecar off and readjust the triple tree. Nonetheless, still a lot of fun to ride and I get compliments whenever I have her out.
shovelhedd
07-04-2018 07:38 PM
