1983 FXDG Clutch Hub Studs
Call ARP just for fun. If someone was stuck they could make you a set. I needed 24 rod bolts for an engine I was building and the OEM bolts were $75 each so I sent ARP one sample and $230 later I had 24 new bolts with rolled threads (the best way to make a fastener). A stud would be a cake-walk for them and fast turn around.
And my rod bolts were not just bolts. They were for titanium rods that used the ground sections as a means of centering the cap on the rod, no dowels, no pins, just the bolts and they need to sustain 9000RPM stints. They can make studs for anything, even old studs from the 60's for a 50HP engine before they had CAD. Just trying to help
I appreciate the help for sure.
I received my "Made in the USA" studs today.
The only problem now is, I can't get the old studs out of the hub.
I'm at a loss right now as to what to do. I'll do some more web searching to see if I can find a video.
The new ones just press in and then I will peen them.
Two ways depending on your skill & tools available , first is use a ball burr and grind out the crushed area on the back of the hub. It's a tapered shallow hole so don't go crazy and then use a roll pin punch and knock them out.
Other way is drill out the crushed part and the the drift punch again, needs decent drill bits, a clean center punch and a steady hand. Be sure to put a nut on all the threaded studs so when you try to peen it over you don't distort the threads. Best way is find a buddy or a shop with a torch setup, heat the end then peen it over. Spot welding the them once peened isn't a bad idea if you have access.
