This can't be original paint, can it?
So I'm going to see it Thursday and I'm prepping myself. This bike is not in good condition. And that's ok. But will I be spending more of my rebuild time with a wire brush and naval jelly or actually working on the mechanicals? I expect grime and some rust. But check out the tank: Just surface rust? Or is more lurking below the ugly paint? Sort of looks like a lot more is trying to peek through.
Attachment 571967
The nacelle isn't much better:
Attachment 571971
The engine is interesting. Just grime or problematic rust? If it's just gaskets and exhaust rusting, no worries. But rusting exhaust ports? No thanks. Thoughts?
Attachment 571969
Attachment 571967
Attachment 571971
Attachment 571969
Iff'n the seller tries to make that a selling point tell him to stuff it in his ***,
Now if you can get it for a decent price,
+ not knowing your mechanical knowledge&background and how far you are willing to go,
The rust&grime you can take care of while ya got it apart,
Peeling paint around the gas hole is where the fumes&liquid gas got under the paint,
Hence the rust from raw metal exposed,
Look inside the tank to see if they coated it&if it is delaminating,
That's a can o worms in its self,
As far as rusting exhaust ports,
Aluminum don't rust,
Concern with the ports is make sure the studs are not stripped out,
There's more but that's all I can think of for now as I've been drinkin,
Turns out that bike was a mess. Gas tank inside was totally rusty. Not just in spots, but the whole thing. It was leaking all over, too. And would need new paint. This one would take a lot to bring back. And for $3800, no way. I found an FXS in much better shape for 3 grand instead. Thanks for the conversation!
TwiZted Biker (10-03-2017)
