1978 Electra glide oil tank
Old 09-24-2017, 11:53 PM
fxwg11's Avatar
fxwg11
fxwg11 is offline
5th Gear
Default 1978 Electra glide oil tank
Want to pull oil tank to replace lines and clean up oil from a leak from oil line attached to bottom of tank. Will removing rear fender give me enough clearance to remove tank. I already have seat and battery removed and tray unbolted did not want to disconnect electrical from tray.
Old 09-25-2017, 02:43 PM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,201 Likes on 1,478 Posts
Can't get it out through the space provided by removing the rear fender. Either needs to come out from the left or right side of the bike. Easiest way is from the right which means you need to disconnect the electrical stuff and get the tray out of the way. Take pictures before doing so and tag/number stuff so you know where it goes (if you don't have a service manual).
Need to remove the bracket attached to the starter motor that supports the left side of the tank and also the bracket that supports the right side. There is a nut on the left side of the bike that supports the bracket on that side. And depending how old the bike is you might consider replacing the rubber supports (three of them; two on the right side and one on the left side.)
Old 09-25-2017, 05:08 PM
fxwg11's Avatar
fxwg11
fxwg11 is offline
5th Gear
Thanks thats what I figured I have everthing unbolted on tank and tray. Was hoping to not have to disconnect electrical, thought maybe removing the fender would give enough room. Thanks for the help and I will differently mark and take pics....good advice!!
Old 09-26-2017, 10:23 AM
panz4ever's Avatar
panz4ever
Also take note of how your oil lines are connected and routed. It is a pretty tight squeeze to get the oil lines all bunched and pushed together to make sure they do not come into contact with your rear exhaust pipe.
Old 09-26-2017, 04:30 PM
fxwg11's Avatar
fxwg11
fxwg11 is offline
5th Gear
Thanks I have marked them it has old steel braided on not sure if I will go with that same set up or heat rated rubber. Next project is to seal off primary with vent line have you ever done this before? I have found a few articles with good info and diagrams.
Old 09-28-2017, 10:58 AM
panz4ever's Avatar
panz4ever
Yes I have. Think I posted a couple of pics that shows how to seal your primary. They were taken from another forum and done by a guy named Hawg Ryder. If you don't have those let me know and I will post them up.
Old 09-28-2017, 05:29 PM
fxwg11's Avatar
fxwg11
fxwg11 is offline
5th Gear
Ok thats the one I have read on Chopcult. Thks
mballard
Shovelhead
35
07-21-2021 10:05 AM
doc308
Shovelhead
05-29-2019 11:42 AM
priceamp
04-26-2014 11:53 AM
Hitechluddite
05-14-2012 01:05 PM
niczumbo
11-10-2007 05:47 PM
Quick Reply: 1978 Electra glide oil tank
