Clutch/tranny bound up?
Old 11-01-2017, 07:26 PM
Chris Sigo's Avatar
Chris Sigo
Chris Sigo is offline
Default Clutch/tranny bound up?
Putting together this ‘75 fxe, and up until recently the shifter worked through all the gears flawlessly, and the kicker action was smooth.
Suddenly the clutch or tranny is now giving me fits in a strange way. Something is bound up so I only get about 90 degrees of rotation in ether direction when rotating the crank. At either end of the limited rotation i can no longer shift into any gear. Right in the middle (when the tension is off) i can. I also can’t move the kicker pedal anymore.
I didn’t reef on the kicker or motor in anyway, i was just trying to find neutral to move the bike and this happened. Video below. Any info? Thanks.
Plugs are out. Chain is off.
Old 11-01-2017, 07:34 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,519 Likes on 2,862 Posts
if it was working before you removed the rear chain link and left if hanging on the front sprocket
I would say its binding up on the chain raping around its self on the front sprocket and its in gear
Chris Sigo (11-01-2017)
Old 11-01-2017, 07:49 PM
Chris Sigo's Avatar
Chris Sigo
It was doing it before i unhooked the chain. Though, just now i got the bike into neutral and re-linked the chain. I can rotate the motor and can spin the wheel backwards but it locks up moving forward!
Old 11-01-2017, 08:31 PM
Chris Sigo's Avatar
Chris Sigo
UPDATE: I may be an idiot. Found a crunched up old hose clamp that was binding up off and on apparently. I should have fished a magnet around on the bike when I first brought it home.
Old 11-01-2017, 08:36 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
cool it was not a normal thing
Breeze62
10-03-2017 09:52 PM
wickedsoftail
Custom Models
08-08-2012 05:40 PM
tgaetto
07-25-2010 05:24 AM
elevenbravo78
EVO
01-22-2010 09:30 AM
Brad90FXRS
EVO
06-04-2007 09:20 PM
Quick Reply: Clutch/tranny bound up?
