Trans Upgrade 80 FLT
Received 4,927 Likes
Have the same conversation with Baker, it will cost more but will be worth it.
Uncle Larry (12-05-2017)
Baker makes a great 6 speed, I put one in my 06 flh 5 years ago, recently got an 81 FLT, most of the guts from the 06 fit the 81. From my experience with 6 speeds and FLT’s I’m saying if you want overdrive change your final sprocket. Also Change the trapdoor, transmission side cover, clutch cable and perch to Twinkie style. I wouldn’t suggest 6 gears.
Number 1...don't buy Revtech anything
Number 2...J&P is going through bankruptcy...don't know that I would order from them.
Number 3 Every one else that carries that part says: We're sorry, this product is currently not in stock and can not be backordered...or Temporarily Unavailable
Number 4...don't buy Revtech anything
EDIT Revtech sells them on ebay
https://www.ebay.com/itm/RevTech-6-S....c100677.m4598
83shovl93”strokr (02-20-2019)
Just bought another one for the FXRS off ebay, 30$ cheaper than JP with the member discount
I would recommend the set, BUT I had do do a couple of mods:
1-the mainshaft final thickness was off and wouldn't fit the bearing of the inner primary. I found out too late, so was out of warranty, so I machined the bearing inner race and works fine
2-the main gear needed a little grinding to fit all the way in into the tranny case
Nick Edwards
12-10-2013 05:08 AM
