Correct Part Number for 1972 FLH Mufflers
I am trying to do a spot on correct restoration of a 1972 FLH Shovelhead and I can't tell if the correct muffler part number is 65244-70A or 65242-70B.
Do I need an A and a B for left and right? Which number is correct?
I have also heard that the B might be an ultra quiet version?
Any insights people can provide would be hugely helpful and much appreciated.
Received 3,210 Likes
Part number not visible on the other side just HD MOCO Inc. I seriously doubt there's a different part number as there doesn't appear to be a reason for it. Mufflers are attached via round hangers that slide onto the mufflers so I wouldn't think there is a right or left. Looked in my parts book and confirmed numbers Panz came up with. IMO the B is the extra quiet and you could use either the 65242-70 or the 65244-70 and decide whether you want the standard or extra quiet.
Hi guys
appreciate this is a really old thread...
I stumbled across it the other day searching for similar info and thought others may be interested in what I have
I have a 1972 FLH with a build date of September 1971
it had some aftermarket pipes on it, but came with some original exhaust parts including mufflers
One muffler is a 65244-70B and has an outlet size of 1inch
Other is a 65244-70A and has an outlet size of 1 3/4 inch
They are the same length and have the same diameter inlet I have made the assumption B is for the right side and A is for the left side
I went with a single system and fitted the B muffler and yes, it's quiet
I couldn't find these numbers in the parts book either but they do look like the mufflers in the book
Cheers
Cheers
