Hey, from Baltimore, MD
Old 04-03-2018, 05:01 PM
Papamud's Avatar
Papamud
Papamud is offline
6th Gear
Default Hey, from Baltimore, MD
Hi guys,
I just joined because an old friend of my family just gave me a 1973 FXE. It hasn't been started in 4-5 years and so I might be needing some help in getting her ready to start...
I got a fresh battery yesterday, and I'm going to put some fresh gas in, check the oil level (I gather that oil will come spewing out of the vent if it's collected over the last few years) and see what happens.
I'm hopeful, but if the carb is gummed up, then I'll run some seafoam through and see what that does.
Other tips/hints?
Thanks!!
Old 04-03-2018, 05:44 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,519 Likes on 2,862 Posts
carb should be sonic cleaned - boat yard some repair shops have as well
new plugs - see what ignition it has ( look ) points change them
do not add oil if it still has a couple of inches in the oil tank, as it for sure is sumped and most will return to the oil tank - if you fill the tank it will get you beat with a broom so much oil will be floating around in the garage and driveway it could take hours to clean and the spot wont go away for at least a year
Old 04-04-2018, 12:01 AM
scooper321's Avatar
scooper321
scooper321 is offline
Got pics? Where are you located? I'm in Canton. Rebuilding a 1980 FXS.
Old 04-04-2018, 12:38 AM
Papamud's Avatar
Papamud
Papamud is offline
6th Gear
So, I started her up tonight and she ran great! Got some bugs to iron out, but I'd happily ride it on the road once those bugs are taken care of.
I need to bleed the brakes and fill with fresh fluid, and the brake light (rear) works when either brake is engaged, but not as a running light, so I have that to figure out. Otherwise, life is good!
She's got the original pipes from 1975 and they were loud, but gorgeous!
Scooper, I'm on the edge of Homeland, near Loyola and Notre Dame. between York Rd. and Charles.
Always up for a ride!
The oil looked clean as a damn whistle, no rust in the tank, tires are fine... I probably need to pull the solenoid and clean it up, check the timing, run a can of seafoam through the SnS and throw some new plugs in, but she ran so sweet, I'm kind of reluctant to mess with it too much!
The clutch is HEAVY. I need to beef my left hand up some, because that Barnett is a beast. Y'all think it'll loosen up a little with some use?
PapaM
Old 04-04-2018, 05:55 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,784 Likes on 3,300 Posts
Sounds like a sweet ride. Congrats and welcome.... The Barnett is what it is... If it runs good I wouldn't mess with it till theres an issue.... Sounds like it was well kept.... Pics would be nice?
Old 04-04-2018, 08:21 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,049 Likes on 1,508 Posts
I do Not recall the Stock Pipes being all that loud... if that is what ya mean by "original pipes"
Old 04-04-2018, 08:23 AM
r-bar-j's Avatar
r-bar-j
r-bar-j is offline
Received 2,038 Likes on 1,938 Posts
Welcome from San Antonio, TX.
Old 04-04-2018, 08:36 AM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
Welcome to the Forum lots of great info here enjoy from Florida Ride a Lot Ride Safe.
Old 04-04-2018, 09:10 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,403 Likes on 876 Posts
welcome from CT. the tail light bulb may have one burned out filament - start with the easy stuff
Old 04-05-2018, 12:33 AM
Papamud's Avatar
Papamud
Papamud is offline
6th Gear
Default Loud pipes and a pic
No, I mean the pipes are from the year 1975. The same year the bike was born. Just seems a long time to me.
Anyway, here is a picture of a nerd with a Harley-Davidson.
I have to replace those buckhorns for something...else.
Quick Reply: Hey, from Baltimore, MD
