Safety wired lug bolts.
Received 4,614 Likes
Common practice on aircraft and some race cars, guy might have had experience in those fields. You can get lock tabs that bend over and lock the original style bolt, think I'd use those before safety wire in this application. Safety wire can often stretch enough to lose some of the torque value, and if they loosened enough for the rotor or pulley, whichever you're talking about, for a slight movement, it would wear and eventually break the bolt off, even if it couldn't turn very far; those bolts take a pounding. Proper torque on the right kind of bolt and a drop of loctite, those bolts should never come loose. Something like a muffler bolt wouldn't be a bad idea to safety wire, lot of vibration, a common bolt to lose - I've lost one, the bolt, not the muffler.
Received 4,911 Likes
B- someone did it because they thought it looked "cool"
The oem tapered lug bolts (screw wheel mounting socket pt # 43530-35A) will center and secure the wheel hub to the brake drum, preventing any forward or backwards movement/rotation between the two. Using regular bolts you take the risk of forward and backward movement/rotation between the wheel hub and brake drum, making the holes in the wheel hub oblong causing excessive vibration, then trashing the wheel hub and possibly locking up the rear wheel.
