My new 66 FLH
Received 4,896 Likes
To help you fund your restoration work, I would be happy to buy that Police hand shifter from you when you get it off the bike. Some inspiration, my 1970 FLH that was closer to stock then yours when I got it, and in the past two years I have been improving that situtation with OP tanks and other goodies. Buy the stock shovel stuff now before they start getting Knuckle prices for them. This is her in Daytona this year.
I might take you up on the offer but I do need to find out more about the bike first. Was it a police bike? No idea. I went to the dealer today and they can't search that far back to give me any info like original colour etc. They did on my 82 wide glide but couldn't on this one. I guess when I sand the paint off it'll be like an archeological dig. Pierce's site shows only 5 colours for 66 which, figured there would be more options.
hellonewman (07-20-2018)
you remove the floor board and its rear mount that bolts to the frame
you remove the muffler then the connecting pipe ( squish pipe ) to both front and rear exhaust - by turning it out ward and down towards the floorboard rear mount and pull it out -- the squish pipe comes out from under the frame / cam cover -- at that point - sometimes the rear exhaust has to be removed as well but that system looks aftermarket so it may just pop out
the only way it comes off and when I tell you its a palm to the forehead
Received 3,212 Likes
Nice find there. Couple of more things for your "to do" list if you choose (that's in addition to what has been posted already). That's an aftermarket rear brake master cylinder. OEM is Warner Lockheed and are painted black. I believe the brake pedal assemblies should not be chrome; the mounting plate...yes, but not the componenets (excluding spring of course).
Floorboards for your year are the rectangular type with the flat mats.
Black kicker arm and return spring. Chrome cover for the spring.
Oil pump is later.
Not sure what those knarly ***** that are on your right side rocker boxes, but those have to go. Should be a domed nut that takes and allen wrench.
Brake drum backing plate should be black painted as should the wheel hubs. No chrome axles.
Not sure if your muffler is aftermarket. I'll dig thru some of my stuff and see if I still have an original for a 2-1 exhaust. The end is definitely different than the "extra quiet" type recommended for use soley on the dual exhaust system. Is your squish pipe and y-connection to the muffler a single piece or two? My 65 uses the single piece pipe. I'll dig and see if I have an extra one and post a pic.
Nice thing is that you have a running machine to enjoy. Definitely ride it and collect parts and over a few winters put her on the stand and add correct components. it may take a few years but if your persist it will pay off.
Oh and lastly herz a link for what John was referring to re: colors.
http://hdpaint.tk
Oil pump is later.
http://hdpaint.tk
Nice find there. Couple of more things for your "to do" list if you choose. That's an aftermarket rear brake master cylinder. OEM is Warner Lockheed and are painted black. I believe the brake pedal assemblies should not be chrome; the mounting plate...yes, but not the componenets (excluding spring of course).
Oil pump is later.
Oil pump is later.
Thank you
I knew the hubs, rims, rear drum and plate are probably taiwan ted and yes its chromed out. I wondered about the rocker bolts, my other one has the allen key version.
What I want to do right away is get the bars, controls and mousetrap on the bike.
The head pipe is one piece. Would love to see pics of the right stuff.
