My new 66 FLH
#71
Pichilingo (04-05-2020)
#72
The differences are subtle in the y-pipe but aftermarket in my opinion. On the OEM one the Y goes over the squish pipe, mine is the other way around and the weld is different where the rear pipe enters the Y. The tip looks like it has a fuse weld on the seam using rollers vs spot welds. Confirms what I assumed but thats okay.
Things on my want list right now are OEM bars, controls, foot shifter complete assembly (with bracket) and a complete mousetrap. Ive seen used OEM bits and pieces on-line so even if I have to suck it up and run a repop mousetrap cover for now I will. Some OEM stuff I imagine is not possible but Ill try.
Oh, and a cast iron oil pump is on that list!
#73
#74
#75
The following 2 users liked this post by johnjzjz:
hellonewman (07-24-2018),
#76
#77
Looking at the edge of the bezel, it appears that someone either took it apart of attempted to take it apart who didn't know what they were doing.
Tombstone is correct for a 66 genny, the pointer/needle isn't correct, it should be a little shorter fluorescent red pointer.
The build code on the back would be correct for an early 66 genny shovel ( J8 ) J= 1965, 8= August.
Something you might want to check out after you get the two round head machine screw in the back to hold the inner (lower unit) secured. Lightly shake it from side to side, if the pointer flops from side to side, chances are the jewel is broken (jewel is a nylon sleeve that holds and guide the pointer peg from moving side to side), this is very common for the 540 series speedo's.
If you decide to get your speedo professionally restored, contact John Bordas, in Texas 1-303-420-4510.
#78
#79
JustDave13 (09-17-2019)
#80
another guy in Canada does speeds and he is expensive but you are in Canada so it might not be for you
his name it will come to me I will get back to you
the new speedo you posted is a re pop look at the face screw mounting compared to yours
