Starter Bendix
My 76 FLH has a bad grinding sound when I hit the starter. Upon tear down I found that the starter Bendix is very rough. Not the gear teeth, but the body of it where it would ride against the back side of the ring gear.
My question is - is there supposed to be something that limits the travel of the Bendix, so the it's body doesn't ride against the ring gear, or is it supposed to push all the way out against the ring gear? FWIW - I have 2 thrust washers in place where the shaft goes into the outer primary cover. It came apart that way, so I've always put it back that way. |
Far as I know the brass washer [quite thick] is what limits travel..
Rough physically?? but it turns freely one way while not the other?? I guess I would start by inspecting the lever, or Carrier, in the primary, that carries [aims] the bendix... also ensure you have the correct width spacer [brass in primary on bendix shaft] number is Not as Important as Width... |
so, does the Bendix travel far enough to come into contact with the back side of the ring gear? I know the Bendix gear mates to the ring gear, obviously. Not sure what brass washer would go between the Bendix and ring gear.
the "face" of my Bendix, the flat part behind the Bendix gear, is all chewed up. Not sure what the back side of the ring gear looks like. It seems like these two surfaces come into contact with each other when engaged. Not sure why/how the Bendix surface is chewed up.
Originally Posted by pjb
(Post 17673169)
https://cimg8.ibsrv.net/gimg/www.hdf...cd431d2183.gif Holds the bendix from over-engagement... btw #7 is in the outer primary for reference.. Edit; Fixed image [I hope] damn well gettin hard to link Pictures these days |
Does your bike have a stock outer primary? I ran into a similar problem on my '68. The bearing that the starter shaft rests in the stock outer primary is flush with the mating surface of the primary. On the aftermarket outer primary, it is recessed. When the Bendix is engaged, it can travel further, hitting the back of the ring gear. If this is the case, you'll need a longer end on your starter shaft. I may have one in my parts stash. |
Originally Posted by Racepres
(Post 17673180)
Number 22
https://partstream.arinet.com/Image?...partfinder.htm Holds the bendix from over-engagement... btw #7 is in the outer primary for reference.. |
Originally Posted by FL54
(Post 17673182)
does that shaft really move in/out, or does the Bendix riding on it only move in/out?
(Post 17673220)
(Post 17673208)
I have 2 big brass washers in the #22 position. I know what you said, the thickness is more important than the number. Could it be that I don't have enough thickness there, and the Bendix is traveling out too far?
© 2024 MH Sub I, LLC dba Internet Brands
