Outside oil return
Old Sep 11, 2018 | 11:21 AM
biginchhustler's Avatar
biginchhustler
Default Outside oil return
lets see what this brings -- I return my oil to the thrust surface of the piston - not in the timing hole
Old Sep 12, 2018 | 08:26 AM
Racepres's Avatar
Racepres
Never seen it done that way... generally into cam chest, or closer to the Breather Gear cavity. On an engine with a better oil scavenging system.. [Sportsters] go to anyplace behind the windage tray.
We used outside oil returns either because of such a big bore there was no room for inside returns, and/or to keep top end oil off of the flywheels.. as a Performance enhancement.
Your shown set-up looks to be returning oil to the approximate location of Stock...
What am I missing here??
as an aside... I learned to severely restrict the oil feed [by an adjustable bypass] during a "run" to eliminate so much excess oil in the engine... Works!!!!
Old Sep 15, 2018 | 10:04 AM
megawatt's Avatar
megawatt
Do you combine both oil returns into that one drain?
I like the idea that it drains back between the crankshaft wheels.
But I suppose the piston skirt spreads it out and it gets all over the place anyway.
Old Sep 15, 2018 | 11:41 AM
biginchhustler
the front and the rear are centered on the cylinder --I have Teflon buttons on the pistons so the oil wont goo through the wrist pin to the other side of the piston-- -- the main idea is for the oil to get on the thrust side of the piston -- might help with piston wear -- -- the oil has to go back to the crank case because the oil is thrown onto the cylinder to lube the rings --
biginchhustler
1 drain for the front and 1 drain for the rear --
Old Sep 17, 2018 | 06:24 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We tie outside drains to the the primary return side of the pump, if running a belt, or primary in it's own oil.
Also, in maximum effort applications, we have pulled unwanted excess oil from the cam chest to the return side of the pump via drilled/tapped 1/6" NPT fittings.
Scott
TheMurf
Oil Archive (no new posts)
Sep 1, 2017 09:43 PM
itellya
Jun 30, 2012 07:24 AM
J2X
Apr 23, 2011 10:01 PM
bikerick
Jan 2, 2009 06:40 PM
Ultradoug
Aug 22, 2008 03:35 PM
