'75 FXE Custom Wiring Review
I'm trying to rework the wiring on a '75 I picked up, that has been rewired but I haven't tested it. A few sections were beat up so I have been cleaning it up. But, when I compare how this is wired to some online diagrams, it fits some but not all. I drew up a rough diagram of how this one is wired. If anyone can look it over and tell me anything that is drastically wrong I would appreciate it. OR if anyone has a simple diagram for both the starter relay (changed to SS) and solenoid that would be great.
Other info:
- No start button. it has an old feeler gauge mounted to jump the solenoid.
- No blinkers, front brake switch, horn, gauges or accessory lights.
- headlight is joined to run both bright and runners, no dimmer switch.
Thanks!
Other info:
Thanks!
Attached is the factory wiring diagram. However, if your bike has some piecemeal harness you may want to consider a complete replacement that has the correct gague and color wires to make it easy to service and troubleshoot any future issues?
https://www.thegoodoldmotorcyclepart...g-Harness-3065
Chris Sigo (09-14-2018)
your relay in the second picture will set off the starter when you turn the key on -- the 86 on the relay is for the button one to relay one to the key on - your ground is usually to the neutral switch so you cant start it in gear -- I have heard I don't need that and then you hear the crash to the floor
Good advice, thanks!
So, if I added a starter button to the 86 tab on the relay, would that make a full circuit? ( Like 86 ------ Starter Button -------- Ignition )
I have a nice fat weatherproof 30 amp momentary button that would mount perfectly under the battery box, it sure would look nicer than a crusty feeler gauge poking out of the solenoid.
