Slap me...don’t work on the bike when tired!!!
Well after my last idiot episode racepres and Johnjzjz gave some good advice: don’t rush, etc. So Friday night I’m dead tired but really want to work on the bike so idiot me decided to thread an e-z coil insert into my stripped ignition hold down screw in my cam cover. Messed it all up and wound up snapping off the stand-off screw for the ignition plate. Now what? I ordered 5/32 and 11/32 end mills to drill and retap. If I go with a new cam cover, do I have to line-ream the pinion and cam bushings?
be careful... ya gots a genuine slowdown on yer hands now
Cam covers should be line reamed... starting from New Bushings. But, I have replaced them.. with Used, after checking a few things [like the cam clearance without the pinion gear].. Checking pinion alignment is more critical, and therefore more difficult...
Experience Keeps a Dear School..... You know the rest.
Bill wallace (01-08-2019)
Received 4,923 Likes
good spot...I meant 5/32 and 11/64 but got my denominators all catty-wampus. Yeah...really. On a Bridgeport mill...really. Want me to send some pics? Can’t use an end mill in a hand drill....yeah...I know...but thanks for the advice. I like end mills because they don’t wander like a drill bit. And I’ll probably weld-fill the hole and re-tap. And I get to use my new Palmgren cross-feed rotary table.
Not necessary. I have a verticle mill. I just assumed you were doing this on the bike by hand. And not knowing tooling, may have indead ordered 2 Lip end Mills on Amazon.
Obiviously, you know tooling.
I did my Apprenticeship as a toolmaker at NN Shipbuilding years ago. My last year was on a large Pratt and Whitney Jig Bore before moving into management.
