Coil Wire Got Very Hot - 75 FXE
Adding signals to my 75 FXE and pulled the seat to trace wires to the rear (original signals were removed along with wires)
Noticed that the coil wire insulation was melted per the attached picture.
Made a small cut and opened the harness up a bit, the wire insulation is fine inside the harness.
Couldn't find any spots on the frame or elsewhere that would indicate contact with the wire and rub-through of insulation to cause a short.
But based on local nature of the issue my guess is that's what happened. Otherwise, the wire insulation would have been fried inside the harness as well, right?
When you have a poor connection (like the one at the coil, it's green) it will create to much resistance and because of that, the wire will heat up and melt the insulation as it did.. I would replace the entire wire or at least back far enough to where you can see good copper...
Thanks guys.
I didn't see the 14 gauge suggestion until after I replaced the wire from the harness out. I'll keep a watch on it.
Made sure all the connections were clean and polished, then gave it a shot of battery terminal corrosion preventative before tightening down.
Then put a dollop of liquid tape over it all to seal it from moisture.
I should probably check all the other connections that are secured with a nut/washer and clean them just for due diligence.
Received 3,220 Likes
couple of things to think about
like Bob had said the connection may have been corroded and that will cause the heat at the spot its corroded
replacing the entire wire as an extra to the harness is what we would do in the shop at the same gauge
having that much heat at the coil connection I would have replaced the coil, or at least run a OHMs test on it as the resister in the coil is not a fan of being over heated - if its points the condenser is also not happy - it will not work for long would be my guess
I had that problem and even had to pay a tow truck 75 dollars
so nothing shorten out but that wire from the coil to the ignition
get an overload sometimes from the circuit breaker, I changed
the circuit breaker and went with the 14 gauge wire and I'm still
running it never had another problem that worked for me but
each to his own
each to his own
Last I saw that ... it was a case of a points system, and walking away with the ignition on... Not only cooked the wires it blew the coil ...literally
I don't think it had any affect on the condenser, as it is just a capacitor.. You will know in a Moment if the condenser was bad... there is Never a Question.. rewire...same gauge... Bigger is Not better... except in Big City America
