Did the 78.5 fxs lowrider come as a 1340 even with the vin starting with 2f
Tim, welcome to the forum.
How high is the engine number? Is it below 60000 or above it? Can you post a partial photo please. Thanks.
What is the first portion of the left crankcase production number? Is it 178? Code number 1 indicates 1200cc.
Or is it 1478? Code number 14 indicates 1340cc.
Eric
Eric
Left crankcase production number may be underneath and near the front. As an example, here is 178 0++ 1++. First 1 is a code number and in this instance it indicates 1200cc (74ci) Shovel.
If the code number was 14, as in 1478, then it would indicate 1340cc (80ci) Shovel.
BTW, your 7 may or may not be the same style as the 7 in my picture. Apparently H-D used at least two types of 7 when stamping 1978 model crankcase production numbers.
R-H crankcase production number is stamped inside the gear compartment and obviously not visible when the engine is assembled.
Do you know if the case halves are original to each other?
Eric
Eric
