Turn Signal question??
On my 1983 FLT classic, I hold the turn signal button down and it blinks, soon as I let off the button it turns off.
Is this normal for this model, on my other bikes the turn signal would stay on 10-20 seconds after I hit the button.
Is there a way to make it stay on briefly without holding the button?
The following 2 users liked this post by Racepres:
Campy Roadie (05-18-2019),
jastephe (05-08-2019)
actually only using 3 poles... Just like holding both Buttons simultaneously..
just ask for one like this
and put the 12v [Green only as that comes from the Flasher unit] to the in [both of them] and purple and brown on the two Outputs..= Switch on for 4 ways...
Should work then... two 12v inputs jumped together fed by Green...one each purple and brown on the Outputs...
HSCIC; I been holding the button for so damn long I do Not believe I could get along with a "set" situation...maybe with a Large economy size Indicator to remind that they are On!!!!
Smiling.. Remembering that my Bitter Half still uses hand signals after all these years, even when on the Back..... hell she used hand signals when she took her MC endorsement test!!!!
hscic (05-08-2019)
