Fxe inner primary cover question
I dismantled the primary drive from my ‘77 fxe to investigate a tranny issue and found that the inner primary cover is very badly cracked all around the main shaft support bearing. It is beyond repair and I need to find another one. The number on the inside of my cover is 60620-74 with a 0 over the number. I saw one advertised with the same number but instead of the 0 over the number , there is a 2 below the number. The cover looks the same and , like mine, is designed for the mid control shifter. Does anyone know if there is any difference between the covers with these numbers?
Also, if anyone happens to have a good cover kicking around, I’m in the market. I’d prefer an OEM item as I’ve heard mixed reviews of the aftermarket ones. Is there a company out there that makes a good, well- fitting cover?
Cover??? or Inner... since you mention the bearing... must be Inner...
Not a usual thing to break an inner... but, My Friend can do it...His Tranny bolts were loose...
Far as I know... FXE is FXE and is also FLH!!! In those years..There is an FX [no E] inner... but you should recognize that there is no Solenoid Hole...
