Shovelhead inner primary/ oil pump hose question
Received 3,210 Likes
Been running my 65 Pan with factory oil line set up since 1970 and never had a problem. Running my 84 FLH and 78 FXE the same and never had a problem with either.
[QUOTE=johnjzjz;18327728]well lets get this correct - the three lines for an oem original system
you can plug off the two rear 1/8 pipe thread fitting holes with plugs - then the feed line in the picture becomes a vent for the primary its self
Does the primary need a vent? Can it vent along the clutch push rod to the trans?
