Crankcase breather for a 72 FLH
Hey guys, my Shovel has no line or filter, just the nipple that comes off the engine. Tired of cleaning up oil after a long sit than start up. Where are you guys running a line and is it to filter? My oil bag is like a softail style so I can't run it into that. LMK, thanks
If I am understanding your question, the crankcase breather hose #5 runs from the oil pump. Here is a diagram of the oil system.
My routing looks like this since I have an oil cooler.
If you will notice, I have no rear chain oiler line #7 (periodically lubricate the chain manually). My crankcase breather hose is not routed to the AC but routed under the bike to the atmosphere using a catch can (not a shovel thing but a safety thing so the vented oil does not find its way under the rear tire.
You can check out my thread, posts #589-608 on the discussion of the catch can and pics.
Then it is your oil pump check valve.
https://www.hdforums.com/forum/evo-c...heck-ball.html
http://www.bigboyzcycles.com/showthread.php?t=87
Thanks for links, read them and it is this that it’s coming from. Pump/engine is fairly new and doesn’t happen when. I ride the bike from time to time so I don’t think the ball needs to be set. My evo’s would do the same thing but I had a hose and a breather that bolted near swing arm so it took a while before I’d have to wipe the oil. My shovel has no hose or anything so it just drops straight down on ground. Was planning on fitting a hose and possibly a breather but trying to find a place to lift and fasten so it’s functional and not an eye sore. Been really looking for pics of what guys are doing (except into air filters) and can’t find a thing. Reason why I posted.
Thinking of just putting a hose to nipple and make sure it’s got some length to it and fasten so if it does leak it will drip on chain. That or fit a breather and mount it somewhere ?
Received 4,923 Likes
hscic (06-20-2019)
