Dual Plug wire routing
How I would do it..
Now,,, Be very careful of primary resistance... especially depending on what Ignition.. Dual fire is Not normally a Dual Plug setup.. unless the ignitions are Stacked [ie Independent as in Fuel Racing Applications]
Yep that’s all figured out. 2 x dyna 5ohm coils and a dyna DS6-2 ignition. They even give you the diagram and notes to hook it up.
i just need photo ideas for plug routing. Had I done this bike from scratch Ida used one of those custom engine mounts that hold two tower coils
Edit: the DS6-2 if memory serves me is configured for single fire, if so no reason to try and jury rig it to run dual fire.
I run that system with the tower coils, works great no issues or trouble timing to single fire. Just time off the front cylinder as usual and run with it.
Not a lot of choices on how to run the plug wires except the stock mount to the rear cyl. and the mid mount to the front. Maybe flipping the coil and spacing it out a bit so the plugs wires face inward, cleaner having them run out along both sides to the plugs that way. Be a pain to play with the wires but .........
I have always utilized single fire with Dual Plugs, ...and I always choose dual fire with Single Plugs..and never single fire..
But... Lots of folks configure the plug wires to create dual Fire utilizing a Single Fire ignition... You Choose...depending on Compression Ration for me...
