Ultima troubles
Old Aug 2, 2023 | 04:51 PM
81shovleheadtillimdead's Avatar
Stage III
Default Ultima troubles
I have an 81 fxs with an ultima 103 in it im trying to time the cam and i cant get my tdc mark to line up with my pinion mark its 8 teeth off . First time iv been into the ultima motor what am i missing ? Oh ya allready checked the keyway on the pinions fine . Im loosing my mind
Old Aug 2, 2023 | 05:24 PM
Stiggy's Avatar
Stiggy
Is your TDC mark noted as "TF" in the window?
Old Aug 2, 2023 | 07:44 PM
Spanners39's Avatar
Spanners39
When timing the cam, you don't use the TDC mark because the cam mark on the crank gear is not aligned to TDC. Just line up the breather and the crank marks with the marks on the cam gear and ignore where the piston is in relation to TDC.
johnjzjz's Avatar
johnjzjz
The cam is not timed to the TDC mark - you use the pinion at 12 o’clock and the one cam mark at 6 o’clock and the other for the breather is around 2 o’clock and the cam gear is around 8 o’clock - put the cover on - set the timing at TDC and turn the trigger till the light goes out - your done
your over thinking it — the ignition is timed at the TDC mark not the cam gears - the cam is on the base circle on one of the TDC up strokes and the other time its at TDC is over lap both valves are open a bit -
Old Aug 2, 2023 | 09:03 PM
TwiZted Biker's Avatar
TwiZted Biker
Make sure the TDC timing mark on the flywheel is in the correct position on the compression stroke on the front cylinder, the cam, pinion and breathers marks should look like this.
Old Aug 2, 2023 | 09:07 PM
Stage III
yes "TF" is what iv been useing for tdc
Old Aug 3, 2023 | 04:50 AM
Stiggy's Avatar
Stiggy
That's correct for an electronic ignition. (Advance weights look for the 3 (vertical line ) 0 mark.
(As Twizted said, on the front cylinder compression stroke.)
Old Aug 3, 2023 | 05:10 PM
Stage III
Finally got it figured out (kind of) ended up useing the advanced mark for the rear cyclinder to time the ignition.. fire.
d rite up and purred like a kitten
Not sure why but i,ll take it as a win..lol thanks for the help everybody
Sarantis Vlassopoulos
Twin Cam Motors
Jun 26, 2022 05:51 AM
Rorin67
Jun 17, 2021 01:22 PM
JGS348
Engine Mechanical Topics
Apr 4, 2020 03:29 PM
jackinthebox
Nov 1, 2010 08:49 PM
chad pickens
May 3, 2010 04:43 PM
