Hey Rodney
Old May 15, 2008 | 06:00 PM
ARBY's Avatar
ARBY
Default Hey Rodney
I'm very interested in the starter switch on your 68. Can you e-me with some more pix and particulars???
Old May 18, 2008 | 08:12 AM
Rodney's Avatar
Rodney
Default RE: Hey Rodney
Hi Arby sorry I missed your post I've been extremely busy lately
I purchased the lever starter system from V Twin PN 32-0956
installation is pretty simple.
remove the outer primary and clutch hub for easy access
remove the electric solenoid assy.
retain the starter drive lever and springs.
install the lever starter and shim the lever for proper engagement and disengagement.
route the only wire from the starter lever to a Bosch type relay then to a late style starter relay which has the primary Positive leads from the battery to the starter.
wiring diagram is included with the kit.
I didn't take any pictures while I installed the switch sorry but its pretty straight forward how the thing works. Its simply removing the electric solenoid with a lever you manually use to push the starter drive into the ring gear and with the thing adjusted correctly once the gear is engaged a set of contact points inside the lever assy. creates a ground which completes the circuit excites the small relay which excites the larger relay and contact all systems go..
let me know if I can be of more help.
BTW so far I am very pleased with the switch.
Old May 19, 2008 | 07:05 PM
ARBY's Avatar
ARBY
Thanks much. V-Twin sems to be out of stock on that part but I'll keep checking. Very unique indeed.
Arby
http://chopperville1.tripod.com
Old May 20, 2008 | 07:42 AM
Rodney's Avatar
Rodney
you Welcome,
yes I noticed the part is back ordered, hopefully they will get it back in stock soon.
The switch had been quite a conversation piece!
Eightball52
Jan 7, 2014 08:25 PM
zeke47
Jan 3, 2013 10:12 AM
sixty7flh
Nov 9, 2012 07:56 PM
sean122774
Aug 23, 2012 03:24 PM
cycocycler
Jun 22, 2005 07:56 PM
