big twin timing trick
saw someone post this on another forum, thought i'd share it with some of you who hate trying to time your bikes with that clear plastic plug that you can't see through.
Yesterday, 06:40 PM
doc68
Forum Chaplain
I put the advance mark in the middle of the window and then mark the alternator rotor and the inner primary with a paint stick and a line. now you can see to time it with a timing light. rev the engine until it quits advancing and set it. if it pings, retard slightly which would be rotating the timer plate counterclockwise.
__________________
Doc
Yesterday, 06:40 PM
doc68
Forum Chaplain
__________________
Doc
rawger (11-13-2017)
I haven't had any luck with being able to see through the plug, so I usually put a pair of safety glasses on to keep the oil mist out of my eyes, but I just may have to try this to avoid the mess.
Not a bad tip. You still get some spray from the primary but no where near what you get from the timing hole. I static time mine, then every blue moon use the light to double check. I just wrap plastic over the timing light and wear safety glasses. If you remove the plug after you start it all you get is a mist and not a squirt of oil if you start it with it removed.
