hard to start 78
Old Jan 7, 2010 | 05:38 PM
Chuckharley's Avatar
Chuckharley
Stage I
Default hard to start 78
Rebuilt carb, new points - has spark. Can pull start. Would valve adjustment help. How do I do that.
Old Jan 7, 2010 | 06:24 PM
sqdealgeorge's Avatar
sqdealgeorge
Solids or hydraulics ? Can pull start ? is this a lawn mower ? Help !
Old Jan 8, 2010 | 01:53 PM
78fxs78's Avatar
78fxs78
Yea, I can't even Pull mine hahaha,
but if you changed points your timing might be too far off, go back and do a static check for the timing, if it ran before I wouldn't worry about the valves unless somebody messed with them but they should be checked sometime.
Old Jan 8, 2010 | 03:22 PM
legacycycles's Avatar
legacycycles
Oops
I hate the junk it answer,but really ditch the points put a good single fire ing.on it and then enjoy the ride.
Old Jan 12, 2010 | 03:04 PM
FLYING's Avatar
FLYING
Did you remove the point cam when you put the points in? and if so could it be 180 degrees off?This could cause the problem.
Chriscozz
Engine Mechanical Topics
Feb 19, 2017 04:40 PM
charris
Jan 23, 2014 11:44 AM
bulldoglr
Electrical/Lighting/Alarm
Mar 1, 2011 09:15 AM
lazyfj
Sep 30, 2010 10:41 PM
albionphill
Panhead
Oct 19, 2007 02:26 PM
