starter shaft/clutch
67 FLH generator shovel. pretty much all stock.
my electric starter WHIRS.. It has done this before and the bendix gear ( starter clutch gear that goes ON the starter shaft was worn. Replaced it, worked.. not this time! without me SEEING what is happening in there I dunno? any ideas? A buddy told me I should get an old primary and cut it so I can operate that and watch. It seemed to flow in and out. (mesh properly.) if I operated the solenoid or the wishbone looking guide, by hand when it was apart. whatdoya think?
dan
dan
Still sounds like it could be the bendix...what kind did you get? Most of the aftermarket ones are junk right out of the box. You can hold the starter shaft in with a screwdriver with the outer primary off to see whats up.
http://www.youtube.com/watch?v=PrMce3cPhq0
Look at the shift lever where the solenoid throws the shift collar (part of the starter clutch gear assembly ) I've seen the braze give way so when the solenoid pulls the plunger in to throw the pinion gear out to mesh with the clutch housing ring gear the broken lever does not allow the mesh but the starter turns
megawatt, ooooooouch. Hope you didn't find this out the hard way!
