80"shovel wiring harness????
i am looking for a diagram to build a fresh wiring harness for my 1981 80" shovel. can anybody help me please???? i am not running blinkers or dash . i am basically looking for the basics headlight tail light starter and ignition,horn, regulator, i have the dyna ignition ,not the fancy compterized one just the basic one.if anybody can help me it would be much appreciated. thank you
1 Attachment(s)
Here's one that I had saved from years ago.
Wiring Diagram
1 Attachment(s)
Here's another one.
thats a goodlooking flh. i thank yall for your time . although i am looking for a diagram for an 80" with the nose cone with the dyna pick up and coil.
The last time I wired mine I used an Ultima wiring harness...very small, has every feature you could possibly want, and you can use as many or as few features as you want. They cost around 2 bills new...but if you watch ebay you can get them much cheaper...I paid $60 for mine.
http://cgi.ebay.com/ebaymotors/ws/eB...em=#vi-content |
Wiring diagram
1 Attachment(s)
Here's one more for anyone that's interested.
thats all i keep finding online too.every diagram i find has points dist. or the crane ignition in the nose cone. i have the dyna pickup module in my nose cone. two posts on the coil for the wires to hook up.i do know that the wires go from the pick up to the little black box to the coil. just dont know witch wires go where. i only have two wires coming out of the nose cone. i may just have to unscramble the harness in the bible and try to make sense of that. o what joy the wrought upon this earth when they made that spider web!wish me luck
1 Attachment(s)
Which Dyna ign. do you have ? the more common " S " with the mechanical advance or the 2000 version ?
If it's the Dyna S it will look like this , if so it's simple you've 2 wires a blue & white both go to the coil no black box . The blue wire goes to the bottom of the coil or right side if mounted between the cylinders . White wire goes to the other terminal & the power wire from the switch goes here too white is the stock color normally . Just trace it out before connecting to the coil so you know , a cheap test light is your friend . IMPORTANT do not hook up a power wire to the blue from the Dyna pickup it will fry it . PM me and I'll email a copy of the instructions to you or go to Dyna's web site they have them for download . http://i754.photobucket.com/albums/x...D/100_0776.jpg http://i754.photobucket.com/albums/x...scan0001-3.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
